Mayhems Blitz Kit Help Water White After 5 Drains?
Solved by W-L,
2 minutes ago, Shadowman said:
NO aluminum!!! both the rads were actually new so not used yet both are Black ice nemesis GTX
Ok you shouldn't have a problem then. If there was residual Part 2 and X1 mixed together the biocides and anticorrosives in the MayehmsX1 must have been what caused that frothing or foaming to occur.
In any case it seems that everything is sorted out, give it a good couple flushes with the de-ionized water, if it doesn't come back and the PH test is good you should be alright to fill it with the Mayhems X1.
