I was wondering what you guys think the best rgb AIO cooling solution is for a ryzen 2700x. I was looking for something rgb to go along witht hte rest of the build. I have liked the look of some of the corsair AIO's, but am open to others. This would be going in a thermaltake core x5 which radiator options can be seen here:
Front: 1 x 360mm , 1 x 280mm , 1 x 200mm
Top: 2 x 360mm , 1 x 280mm , 1 x 400mm
Rear: 1 x 120mm , 1 x 140mm
Bottom: 2 x 360mm
Left / Right Side: 1 x 360mm
Any reccomendations are much appreciated!
https://linustechtips.com/topic/949159-best-rgb-aio/
kraken x62 (280mm) if you ask me, though the price is the downer.
Desktop benching:
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547603
I don't really have much experience with NZXT. Is this compatible with the "NZXT Hue" i believe it is. I was wodnering if there are any AIOs that are compatible with Asus Auras?
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547612
http://www.coolermaster.com/cooling/cpu-liquid-cooler/masterliquid-ml240r-rgb/
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547675
2 minutes ago, pallen98 said:
This seems like a good option thank you.
yeah i was going to buy that but then i wanted a 280mm aio, so i got the evga 280 clc
Ive heard that the stock TIM comes in a tube so it doesnt dry up and is actually good.
Np
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547682
NZXT products are the only products that are compatible with NZXT's "Hue" rgb lighting system.
For Asus Aura, refer to this link: https://www.asus.com/campaign/aura/us/Partners-and-promotions.html
However I would advise against most of those cheaper coolers
On 11/29/2017 at 7:22 PM, PopsiclesInMyCellar said:
I've realized that a liquid CPU cooler is probably the dumbest thing to prioritize RGB with. The highest priority should be reliability, i.e., which manufacturer/AIO has the FEWEST reportages of leaks, etc.
Doing some research this looks to be Corsair. What does everything think of my new stance?
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547683
Bottom: 2 x 360mm
PFFT.
Forget an AIO, just do the following!
Pick up 6 - 360mm rads
Grab a d5/res combo unit
Pickup a cpu block of your choice
pickup a gpu block of your choice
Pickup either some UV tubing or UV fluid
Pickup some UV lights and maybe some RGB led strips.
Pickup some RGB Fans you will need 36-120mm
Now set those fans to an inaudible 400 rpm.
LOL as your have a completely silent pc that runs around a 3-5c DeltaT.
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547694
3 minutes ago, AngryBeaver said:
PFFT.
total cost: 6 rads: 330$
18 fans: 180$
a ton of cables: 50$
some fittings: 50$
RGB cpu and gpu block: 100$
fluid: 20$
led strips: 10$
Time: 4 hours
total cost: a shit ton
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547700
18 fans: 180$
some fittings: 50$
fluid: 20$
led strips: 10$
Time: 4 hours
Maybe if you go cheap!
6 rads = 450-500
36 fans (push pull) ML120 RGB = $25-30 per fan so at $25 = $900
Tubing would be about 2 boxes at 25 per box for $50
Fittings would be up there about 8 per fitting and we need about 14 so about $115
RGB Cpu block = 80-120  call it $100
RGB glu block = $175
Fluid = 25x2 for $50
Led Strips = $40
Time = free
d5/res combo $150
Total cost = $2080
But this will last for several builds with the exception of replacing fans that die, a potential pump, and changing a gpu block... the rest will stay for a decade without issues.
You will get superior cooling power that is near silent. It will look beast and if you go hard tubing even better. Who cares about cost!
Or you could spend $125-200 on a boring AIO with some RGB lights on it.
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547748
OMG not cooler master's cheap stuff. They look good, but cooling performance is worse compared to the others and build quality is doubtful. Gamers Nexus broke their test sample because one of the liquid channels are right behind the screw hole for the fans. They just so happen to use a slightly longer screw, and the screw punched right through, leaking coolant everywhere.
Desktop benching:
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547751
6 rads = 450-500
Led Strips = $40
Time = free
d5/res combo $150
Total cost = $2080
thats more than my build...  i think you can get cheaper rgb blocks
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547753
Cheaper yes. Better, no. If you are spending the money to go custom then you don't cheap out on crucial components.
If he wanted to save money he would just drop 4 of the rads to cut the price by a huge margin and 2 360mm rads is more than enough for a cpu and gpu.
So -333 for rad cost
- 600 for fan cost
- 70 ish for fittings
-25 for tubing
-25 for fluid
-20 for led
= about $1005 total cost.
custom water isn't cheap, but imo it is worth it :-D.
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547789
its not their cheap stuff, its 120$ its not a ML lite,
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547811
then too bad they couldnt make expensive stuff better.
Desktop benching:
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547838
13 minutes ago, Firewrath9 said:
thx for that info, so I'll stop recommending Corsair AIOs unless they are notceably cheaper than others.
Desktop benching:
https://linustechtips.com/topic/949159-best-rgb-aio/#findComment-11547904
