So i was bored today and my cousin and I decided to see how my CPU is, anyway I have the AMD FX 4300 and managed to overclock it to 4.6ghz on the stock cooler, how long could I expect before the CPU decided enough is enough? Should I tone it back down as I plan to buy a new computer in the next week or so
https://linustechtips.com/topic/94901-how-long-before-itll-die/
idle is about 30-35 Celsius and i only need it untill my new hardware comes
is it stable?
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/94901-how-long-before-itll-die/#findComment-1271660
It booted at 4.8ghz but as soon as i did anything the computer stopped, but im currently just on general internet at 4.6ghz and it seems fine
run prime95 small fft's and check the temps. if it is over 90, please turn it down a bit
https://linustechtips.com/topic/94901-how-long-before-itll-die/#findComment-1271668
internet = idleing, it will crash in the first few minutes of overheating 100% sure
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/94901-how-long-before-itll-die/#findComment-1271677
On a stock cooler it will hit thermal limits and shut down at 100 C before you can really do any damage with voltage.
Its an AMD processor the max thermal temp limit is 65C, OP probably baked the chip, AMD does not make its processors the same way Intel does and as such they have a far lower thermal limit. Itel rates most of their processors into the 90C range. That chip wont last long if you run it that far out of spec.
https://linustechtips.com/topic/94901-how-long-before-itll-die/#findComment-1271830
I have had an 8150 auto shut off at 100C. Had a AIO cooler fail and managed to get in the bios long enough to watch CPU temp reach 99C and shut off.
I have also had my 8350 into 90C range before with ALOT of voltage and core speed. Both chips run fine and you are correct they are rated for a much lower temp.
So him running hot for a week or so wont kill it off immediately and he will either BSOD or auto shut down because the CPU will spike in temp very fast with the stock cooler.
https://linustechtips.com/topic/94901-how-long-before-itll-die/#findComment-1271867
