vga to hdmi converter not working
Solved by samcool55,
The adapter only works in 1 way, HDMI input -> VGA output.
You are trying to use it the other way round, which doesn't work.
It's a HDMI to VGA adapter and not a VGA to HDMI adapter.
Nothing you can do about, the active piece of the adapter is what needs to be changed which isn't exactly something you can easily do.
Featured Topics
2
9
CDR_Xavier ·
Posted in Build Logs1 -
McBeth1087 ·
Posted in New Builds and Planning11 -
7
NamelessUser ·
Posted in Troubleshooting1 -
HereWeGo ·
Posted in Power Supplies3
