Software to add a foreign network to same lan?
KhandakeF
Is there any way to add a computer that's not on my network and have it act like its on the same network?
I'm trying to play with someone else on Minecraft and I want to use the lan function so we can play together, but he's not on my network
Wii-U Wii-U Wii-U Wii-U Wii-U Wii-U Wii-U *insert firetruck picture* :)
Hamachi is probably the easiest if you aren't familiar with VPN.
There's usually a layer 2 or layer 3 consideration, for just playing minecraft any sort of LAN<->LAN tunnel would work like traditional IPsec or OpenVPN since it doesn't require hosts to discover each other via the same subnet.  If you didn't have a more automated solution like Hamachi you'd have to set up a tunnel on both routers.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
