So I am waiting on my paycheck to come in so I can breakdown and buy individually sleeved psu cables. I am going with white and black. I want to get combs, but I am not sure which I should I go with. Should it be white, black, or transparent combs?
Instructions for frustration management:
1) Sit at desk.   2) Repeatedly slam forehead against desk.
I never said I was smart, just smart enough to be dangerous.
ORLY?
……..'|:::::::,': : : : : : :_„„-: : : : : : : : ~--„_: |'
………|::::::|: : : „--~~'''~~''''''''-„…_..„~''''''''''''¯|
………|:::::,':_„„-|: : :_„---~: : :|''¯¯''''|: ~---„_: ||
……..,~-,_/'': : : |:    ͡° ͜ʖ ͡°) : |: : : :|:  ( ͡° ͜ʖ ͡°)): \..|
……../,'-,: : : : : ''-,_______,-'': : : : ''-„_____|
………',:': : : : : : : : : : : : :,-'__: : : :_',: : : : ;: ,'
……….'-,-': : : : : :___„-: : :'': : ¯''~~'': ': : ~--|'
………….'|: \: : : : : : : : -,„_„„-~~--~--„_: :: |
You have been visited by the propane god, I tell ya hwat. Repost this on 5 more profiles or Hank Hill will bring the propain.
- credit to, @Cinnabar Sonar
https://linustechtips.com/topic/942290-psu-cable-comb-color/
If you're buying white and black cables, I'd personally go for the transparent combos so that none of the colours will pop out more than the other.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11484805
13 hours ago, James Evens said:
If you can't hide it make it awsome. Solid metal (aluminium) cable combs which can be anodized if needed are available.
Eh, not my "style".
@TVwazhere, what are your thoughts?
ORLY?
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11484845
22 hours ago, dual290x said:
Eh, not my "style".
Assuming you're mixing both black and white within the same cable (24 pin, 8 pin EPS, 6+2 PCI-E), I'd probably go with clear combs, that way, they dont stand out as much. There's also two styles, the clip on style, and the more permanent over the cables.
Image result for cable combs
Image result for cable ensourced
Personally I kinda like the look of the over the cable combs, so if you're buying from a company that offers those, I'd get them. I think they also hold the cables together a bit better. The clip ones though are better if you're indecisive and want to change them out for any reason
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11487733
@dual290x Black is my preferred - otherwise transparent also looks great with such a setup.
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11489833
I started thinking about the comb colors and adding green (not just because of nvidia but because I have always liked green). Which pattern should I go with. My build is black and white with green coolant for watercooling coming very soon.
ORLY?
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11491350
-snip-
I think it depends on exactly how much white, black and green you already have in the system. For example if the only green is from the nvidia gpu (white RAD and black fittings) then you might want to consider slightly more green for the PSU cables. (I'm assuming Green loop fluid?) Perhaps a similar pattern to the one Cablemod posted but replaces all the black with green.
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506270
The MSI Z97s Krait Edition has black and white on it with black ram sticks and white ram sticks from Kingston Hyperx (sorry I am at work and not close to my pc to make a picture). Green from 980 GPU and coolant will be green as you assumed.
So you are thinking something like this?
ORLY?
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506314
Yes basically that. I think that looks pretty decent.
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506343
Even with the white rad being almost right up against it? I am not the best at seeing things in my head.
ORLY?
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506345
Should be fine.
@stealth80 's build for reference. Pretend the blue is green :P
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506359
11 minutes ago, TVwazhere said:
Should be fine.
Okay you seem to know what you are talking about. :P Don't forget though this is in the haf xb evo. I no longer have my darling Level 10 GT.
ORLY?
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506364
Okay you seem to know what you are talking about. Don't forget though this is in the haf xb evo. I no longer have my darling Level 10 GT.
You and me both Lol. Poor LEvel 10's, they had a good run
Her;es some examples of cable managemtn in the Haf XB Evo I found
https://pcpartpicker.com/b/gCtgXL
https://pcpartpicker.com/b/wfV6Mp
https://pcpartpicker.com/b/YDw6Mp (<- this guy's using a white rad too)
https://pcpartpicker.com/b/wq4qqs
https://pcpartpicker.com/b/c48Ycf (<- red cables so you can at least get a custom cable idea)
Finding a Half build with custom cables is actually difficult LOL
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506404
Remember, you can have white connectors aswell, I guess it depends on your over all theme
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11506507
 B&W motherboard and b&w ram with green accents.
ORLY?
https://linustechtips.com/topic/942290-psu-cable-comb-color/#findComment-11510501
