Best type of Ethernet cable?
SM Phoo
I get 2-250mb with my internet provider and I need a 6m cable running from my PC to the router.
It may be a stupid question, but are there better cables than others?
My wireless dongle keeps dropping connection when playing online games, which is really frustrating, so I want to run direct
Thanks
Anything cat5e or better should give you the same experience.  It's generally a waste to go higher unless you have long runs (50m+) and higher speed interfaces (10gbit).
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
Just avoid CCA (copper clad aluminum) cables and you'll be good :)
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
