Something blew up in my Samsung Smart TV, Help!
Solved by iRileyx,
3 minutes ago, ZeferiniX said:Haven't thought of that, thanks. I think I see a "R 221K 1KV". Not sure with the last letter, if it's U or V.
The top result on my google result is showing a "B 221K 1KV" from ebay. Now I'm confused as results are showing "B" and not "R".
Very well could be a B now you've said it, is it as hard to make out in real life as it is on the picture?
Could be either of them, but if there's no result for it with an R, safe to say it is actually a B.
Edit - had a quick look at the reviews for the B one on eBay, definitely seems like the one you need.
