Just now, Joltzz said:
It is almost my birthday and I am going to buy some parts I have watched videos and all of that type of stuff but is it as easy as they say it is?
as ling as you do your due diligence, you should be fine. Also, if something doesn't seem to want to go in, don't force it.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385079
The hardest part about building a computer (imo), is choosing proper parts.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385090
It's not that hard tbh. There are tons of resources and you can talk to people on this forum if you run into any trouble. I would say the first one is kinda weird because you figure out how to do the small things that some don't really go over well. Like plugging in fans into the fam headers and making sure you plug the cpu fan into the cpu fan header. Honestly the most difficult part for me was the headers. The rest seems really easy the.
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385091
I would say the hardest thing about building a pc is choosing which pc parts you want to build it with.
Actually putting the parts together is like building with lego once you get the hang of it, Just make sure you do your research for things like (pushing down gently on the ram to get it in properly) and stuff like that and you will be fine.
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385103
If the you've never built a PC, and you have slight OCD, hardest part is doing cable management and getting everything spot on. My grandma and grandpa (In their 60s) did it themselfs just with me telling them how. it's really easy! Don't expect it to be impossible.
First that PSU. Put CPU in, put the ram in, put the motherboard in, install the cooler. plug everything in along with the storage. Then fine fit the cables in places, put GPU in, and done.
We are always here and it's never ok to give up. :)
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385120
Building, although tedious, isn't too difficult; however, I'd recommend doing two things; making a parts list on this forum (You'll get lots of good advice and spend money better) and following some sort of build guide. Although components will be different, a large majority of the advice still applies, which may save you from making mistakes.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385124
Building in an open test bench with no cable management is easy
Building in an ATX case without cable management is still easy, you just look for holes to get your cables through
Building in an ATX case with cable management is challenging, You will spend time trying to find the route for the cables that shows them the least from the front
Building in an ATX case with cable management and nearly as much parts as it will ever hold (fully-populating the drive bays, fan mountings etc) is difficult. This is what I faced and end up having. RHFxt5q.jpg
Building in an mATX case multiplies the difficulty, while mITX cases exponentially increases the difficulty.
Desktop benching:
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385154
Vibrations? xD *PC vibrator*
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385376
What vibration?
Desktop benching:
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11385815
For the most part, for a plain vanilla build, it is straightforward. The one part I struggled early on were the case i/o cables to mobo
But once u set yourself goals/standards, like cable management, cable modifications, air flow management, even delidding, custom waterloops and radiator placement.  it becomes tedious and time consuming.
https://linustechtips.com/topic/931456-is-building-a-pc-easy/#findComment-11386417
