Are chinese power supplies reliable?
1 hour ago, Anduin said:Hello guys, I'm planning to run two r9 390x on my pc,
Don't.
No, seriously, don't do that!
I have two R9-280X (7970GHz) and at the time it wasn't that bad of an idea. But that was something like 5 Years ago or so.
Today things are a bit different and most games just don't work with multiple graphics cards wich means they either don't work or they cause problems/instabilitys...
But here we are talking about the devil's circle:
Because nobody had/has SLI/CF; the geme developers don't care about it much.
And because the Game Developers don't care much about SLI/CF, nobody buys them.
Wolfenstein the NEw Colossus is one of those Games that don't support two Graphics cards...
1 hour ago, Anduin said:but my current psu is Corsair cs650m, which obviously won't be enough.
WIthout ANy OC on anything it could be enough for testing purposes/short Benchmark runs.
Though I'm not sure about normal operation because I do not have a Hawaii based graphics card and don't plan on gettin one either...
1 hour ago, Anduin said:I can get a Thermaltake Smart Pro RGB 850W Bronze for a really good price, but I feel like 850w is cutting it way too close.
YOu feel wrong.
But I wouldn't get a Bronze unit at that wattage.
I'd get a Platinum one if possible or at least a good quality 80plus Gold one.
1 hour ago, Anduin said:Which leads to the question - is it okay to buy a chinese power supply, and more specifically this one?
Are there any non CHinese made PSU you could buy right now??
Except for the Cooler Master Made in Japan Thingy for 1000 bucks...
But, as usual with such broad questions:
Some are good, many are bad. Without knowing what is good, you'd buy a potato or a lemon.
57 minutes ago, Herman Mcpootis said:850w is enough, but even then i'd just sell both of them and get a 1070ti/1080 with the money instead. One 390x alone eats a ton of power, let alone 2 of them.
Depends on the 390(x)
There are some with open Power Limit, there are ones without.
At Default they're not that bad, well not worse than other highest end Cards.
But with OC they can be really bad.
But I agree with the non SLI/CF Statement. Two Graphics cards are just something you want to play around with, not because it makes sense or is a good idea.
