Possible Upgrade Questions
On 5/14/2018 at 3:46 PM, TVwazhere said:Sometimes there's very little difference between boards with similar SKU's from the same manufacturer, and for most users it doesnt matter, so the cheapest is usually the recommended in that situation. In your case, you actually found a rare 1xx chipset board that used DDR3 memory as opposed to DDR4 RAM, which is what almost every board made since 2015 is using. This isnt necessarily a bad thing per say, but it severely limits any motherboard upgrades since if you wanted to keep the RAM, you'd have a hard time finding a good motherboard that supports DDR3 (and buying ram SUCKS in todays market)
First of all thank you for the detailed response i figured some things but i think i lost you somewhere here (in the quoted part).
I said that my motherboard uses DDR4 memory not DDR3 (except if i misanderstood something)
