3 monitor mount?
cfrozer
i have 2 VG248QE and a dell s2417dg. all are 24" I would like one that can curve towards me and have no sag. The Dell monitor weight 12.72 pounds and the VG248QE are 12.13Lb. thanks0
i7-7700k @4.8GHz
Asus Maxmius IX hero
EVGA GTX 1080Ti FTW 3
850w EVGA PSU
32GB corsair LPX ddr4 ram
Just look up any versa mount and it will work. They all have size and weight specs in the description. I usually use any old mount and they work the same. As long as you read the max weight and length per monitor
I'd just get three single arm mounts, then you can place them wherever you want.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
