If you thought water cooling is more quiet than air cooling then you've been badly mistaken. Especially the cheaper AIOs can be a tad noisy.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/923419-liquid-cooler-noise/#findComment-11308345
seems like there is some air in your loop. try moving your case around a bit shifting it from side to side to see if you can getthe air trapped in the radiator where it should be silent :)
https://linustechtips.com/topic/923419-liquid-cooler-noise/#findComment-11308348
And if you can't get the noise to stop in any way, RMA it.
https://linustechtips.com/topic/923419-liquid-cooler-noise/#findComment-11308389
24 minutes ago, Geniusjohn86 said:
Don't know if yous can hear that but here it is
Voice 007.m4a
definitely air in the pump. it should settle on its own, or you could justtry moving it around, pinchin the tubes that sort of stuff.
https://linustechtips.com/topic/923419-liquid-cooler-noise/#findComment-11308428
The sound is gone now thanks, just a bit worried for a sec lol
It will do this everytime you move it. So if you disconnect it, pull it from it's place to clean, it will probably do it again until the air gets trapped in the reservoir.
https://linustechtips.com/topic/923419-liquid-cooler-noise/#findComment-11308529
Liquid cooling has the potential to be more quiet, but it depends on a lot of different things. I still would choose liquid cooling over big air any day.
https://linustechtips.com/topic/923419-liquid-cooler-noise/#findComment-11309110
