Need your help with a Server PC build
14 hours ago, Meet Vora said:
Context:
I am making a server for my family's small business for data pooling, backups and redundancy. The total data will not exceed 1tb (for a year at least), and there will be a maximum of seven to eight computers accessing it at any time. Keeping the budget low is paramount. I have decided to go with Ryzen 3 processor and a sub $100 Motherboard. For the OS, I have decided to use ClearOS, although all my client computers run windows. I intend to use samba or similar, to enable access.
Questions about the build:
1. I know servers are conventionally better off running chips like Xeons with ECC memory, but the only affordable Xeon I was able to find is the Intel Xeon Processor E3110 (6M Cache, 3.00 GHz, 1333 Mhz FSB) that costs around $140. Can I get away with using a consumer grade CPU like a Ryzen 3? (or Celeron/Pentium?) (Note: It seems that the Xeon is a bit dated [2008] and it doesn't perform that well for that price)
2. What motherboard should I choose? Is the MSI ProSeries AMD Ryzen A320 DDR4 VR Ready USB 3 micro-ATX Motherboard (A320M PRO-VD PLUS) a good choice?
Questions about RAID 1:
1. Does every motherboard support raid? If not, does the one mentioned support RAID?
2. Do I need to get a raid card for RAID 1?
3. If yes, is this a good choice: Syba Combo SATA III (6.0Gbps) + IDE Ports (2+1) PCI-Express RAID 0, 1 Card SD-PEX40035?
Any suggestions for the hardware and OS are welcome!
Sandy Bridge Xeons are CHEAP!
Here's a quad core e3-1220 for $38
Supermicro server board for $50 including heatsink. Dual network ports PLUS IPMI for remote management and six onboard SATA ports - no need to buy an add on card for more ports.
This board supports (requires?) ECC RAM. Which is a good thing because it's ECC and more importantly because older and slower server memory pricing hasn't gone full retard lately. I just bought 48GB of ECC DDR3 the othe day for $210 Canadian. Here's 8GB for $50
Get two of the 16GB Samsung SSDs. Yes 16GB. You set them up in a software RAID 1 mirror set for your boot device. You don't need anything bigger than that for your OS. NEVER, EVER put your OS and your data on the same drive. These are server grade drives and should last forever, but keeping them in a RAID 1 will ensure that if one of them fails, your OS will keep happily running along with no downtime for the users. These are going for $18, but I have seen and purchased some for as low as $12/each.
For power supply, just go with Seasonic. In my experience and opinion they are absolutely bulletproof. Look what $25 gets you. An overkill 430 watt unit that will outlive you.
Get four drives for storage and you're good to go. You can get WD Red NAS 2tb drives for about $50. Put the four in RAID5 and you have 6TB of Storage with the ability to loose one data drive and not loose any data. Plus you can pick up a 6TB external drive for $100 and back up your complete RAID array for offsite storage.
Not counting your data drives, the auctions I linked add up to $199 US. Another $200 for the four drives and $100 for a external back up device puts you at $500. That's for top quality server grade hardware.
Oh and FYI - that's the exact mobo and CPU that I was running on my Plex server. With 16GB of RAM, it has enough horsepower to transcode 4 simultaneous 1080p streams and saturate a 10gb network card while recording from 4 security cameras to a RAID1 array.
