Motherboard Suggestion(Z370 vs H370 VS b360) for 8700k, I won't overclock.
I am going to buy a new pc with 8700k[higher base clock compared to 8700,better resell value i guess and number 1 chip right now :P]. I won't overclock now at all.I won't spend more than $60 for an aftermarket cooler.I will use one GTX 1070 Ti, never ever going to use sli or crossfirex. For RAM I shall buy G skill Trident Z RGB 2400bus.I have heard going 3200 bus for RAM doesn't improve performance that much. Is that true?
Now should I buy a Z series motherboard ? .For example if I buy ASUS rog strix B360-F/H370-F instead of an Asus rog strix Z370-F I can save $100.
Now If I don't overclock does buying B360/H370 hampers my overall performance? Is there any difference between Asus B360-F and H370-F ? I coulndt find any.
If you really have no plan on overclocking, I suggest you just stick with the Non-K Variant and save yourself a few $$. Both CPU are almost the same performance at stock clock. (Quote me if im wrong)
Command Centre
CPU - Intel® Core™ i7-6950X Extreme Edition | CPU Cooler - EVGA CLC 280MM | Motherboard -  ASUS X99-E WS/USB 3.1  | RAM -  Corsair Dominator® Platinum Series 64GB (8 x 8GB) 3200Mhz | Graphics Card (CrossFire) - XFX Radeon RX Vega 64 8GB HBM2 - XFX Radeon RX Vega 64 8GB HBM2  | Power Supply - Corsair AX1200i | Storage - WD Caviar Black 4TB (WD4003FZEX) | Sammsung 960 Pro M.2 SSD 512GB  | Case - In Win 909 (Silver)
Battlestation
CPU - Intel® Core™ i7-8086K Limited Edition | CPU Cooler - EVGA CLC 280MM | Motherboard -  EVGA Z370 Classfied K  | RAM -    | Graphics Card - [No GPU] AMD Navi? | Power Supply - EVGA SuperNova 1000 T2 | Storage -  | Case - In Win 303 (Black)
Operating System - Microsoft Windows 10 Pro | Peripherals - Filco Majestouch-2 NKR 104 ASCII with Cherry MX Red Switch | Logitech G Pro Tenkeyless Mechanical Gaming Keyboard | Logitech G903 Wireless Gaming Mouse | Microsoft Xbox One Elite Controller | Audio - Røde NT-USB | Sennheiser GSX 1000 | Sennheiser HD 599
 if I don't overclock cpu,ram and don't need SLI,crossfirex extra PCIE slot do I need High end Motherboard for processor such as  8700,8700k?
No, performance isn't affected.
Please don't make multiple threads for the same discussion. They have been merged.
No.
If you won't overclock or use any of the advanced features get an 8700 and a b360 motherboard.
sudo chmod -R 000 /*
If you do get the 8700K, I recommend getting a Z chipset.
Even if you don't overclock now, you might in a few years.
Otherwise just get the 8700 non K. Performance at stock speeds is identical. The K is only worth if you will overclock it.
Not only will you save money on the motherboard, but also on the CPU.
