Will two 4 pin fans work on one 4pin connection on motherboard?
Solved by W-L,
Just now, Tadziunia said:Hi guys, i have dillema, i going to upgrade my cpu cooler fans, am going to buy two corsair ml120 red 4pin fans, and problem is, that i have one 4pin connection on motherboard. I have spillter which doesn't have third pin on the second connector only fourh pin, So once again one side of splitter has all 4pin, another has 3 pins (first,second and fourth). My question is. Will i be able to control both fans at the same time from that 4pin connection ? will rpm split equally ?
Both fans will be controlled as a group, the reason for the missing pin on the second splitter connection is for the RPM where only one fan send signal back to the motherboard and the second fan connected just follows via the PWM signal.
