Anywhere to get GEFORCE GTX Replacement Sticker
tehx
Hi. So I peeled of the 'GEFORCE GTX' Sticker on my ASUS Strix 1080ti thinking that the letters were engraved in and not just stuck on. Is there anywhere to get a replacement sticker to stick on.
Here is a pic of what I'm talking about:
sorry i am ocd
3 minutes ago, Ross Scarlet said:
Can't you just adhere it back?
it has lost its stick and has all pieces of dust stuck to it
I suppose you could get some sort of transparent glue/adhesive to help stick it back. Rub a bit of alcohol on the spot where the sticker was and the back of the sticker itself to clean any residue/dust off.
i think i lost the sticker tho
Oh. Then I suppose making one is the easiest way. Font is publicly available iirc.
I would say your 100 perdent fucked then
My life
make one for my i will pay $20
Theres probably services within your country that can do that for you. All I can do is give you a the image.
how do I print a sticker tho lol
Where do you live?
6 minutes ago, Himommies said:
it sounds
it sounds easier just to buy another 1080ti
3 minutes ago, Assassinguy2623 said:
it sounds it sounds easier just to buy another 1080ti
Theres bound to be a service online or locally that can do this for you.
is it possible asus would send me one?
I have absolutely no idea, you can try contacting them.
You took the Sticker off so I'll give you $400 because you just damaged the graphics quality by removing that sticker
JUST SPEND THE $5 AND CONTACT A PRINT SHOP
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
12 hours ago, Himommies said:
Can someone who has the card tell me the dimensions of the sticker please
Is it that serious?
Just now, MANDINGO said:
Is it that serious?
yes
You should find it on aliexpress.com or ebay for sure
55 minutes ago, Assassinguy2623 said:
yes
I'l buy it if you dont want it anymore
