450W power supply
Solved by Spotty,
You're trusting $2,500 worth of PC parts with a $30 power supply that is showing signs it is failing and unable to handle the load your system is putting on it...
... And you're still questioning whether or not you should replace it?
Yes. Replace it.
With the 4.5Ghz overclock and your GPU boost you will probably be using 450W or more which will explain the unexpected crashes. At the very least you should disable your overclock until you replace the PSU.
