I look at a case based on expandability and functionality and 100% ignore visuals / rgb / tempered glass stuff. if I need to I can paint/weld anything to a case if need be.
tempered glass reminds me a lot of those fake wood 1980s console stereo cabinets so i usually avoid going back to that look again
19 minutes ago, Cool_BoyD^-^ said:
If you guys have to buy a new pc case (m itx,m atx or atx), what are the things you will look for?
Pros:
Good tempered glass/side panel mounting System (or at least ones that dont suck)
More than just 240mm RAD support. (280, 360. anything more is a bonus but starts making cases bigger than they need to be)
Good airflow, either mesh front, or Proper vertical side ventilation
Proper implementation of a PSU shroud, with SSD mounts, ventilation holes on the top, a top door for RADS, or a combination of the three
Smart cable management features. Fractal, NZXT and Phanteks have their ducks in a row. The rest have some left to be desired.
PSU Bracket and AIO Brackets for easy installation
Modular/Removable Hard Drive cages
3.1 Gen 2 Type C (not all Type C ports run at the faster speed, you need the new connector for it)
Cons
Horizontal (top and bottom) intakes (P400 and S340)
RGB thats Proprietary (NZXT, Corsair, etc)
Indifferent
Native Vertical GPU mounts (ONLY use these if you're watercooling your GPU!!!)
I look first at functionality, which is very subjective.
1. I want a exterior bay for a Bluray Drive, most people don't want these anymore, but I still use CD's alot
2. I want good front bay i/o, though if a case hase everything else going for it and has an expansion bay this can be fixed with a $20 expansion bay piece
3. Good cable management options
4. Airflow design
5. Spacious, room for fans and drives
6. No molex connectors. When a case comes with a bunch of molex fans and front i/o, it's either old or built cheaply, and if they used cheap fans and front i/o, there's a good chance they cheaped out in other areas
7. Good material feel, I know this may seem not a functional matter, but details count. If they have ugly plain steel innards, that's the same as the molex connectors. I look for quality details and design, because these case manufacturers are companies at the end of the day. They could make more money buy focusing only on the important things, so when I see a company focus on the less important things, the little details, I know they care about the customer too, not just the bottom line. It lets me trust that their product will last.
Having said all that, I'm not buying a case again. I'm building my own desk where the top drawer on the left is my PC case
It will be easily customized, able to be changed and upgraded down the road, and it will have whatever features I want along with great linear airflow
Insanity is not the absence of sanity, but the willingness to ignore it for a purpose. Chaos is the result of this choice. I relish in both.
Can I get an AMEN
Screw Molex.
  1. It has room and convenient mounting for everything I plan to fit inside
  2. It has room and convenient mounting for everything I plan to fit inside
  3. Good Airflow and fan placement
  4. Good Dust filtering (good filters where they matter, easy removal and cleaning of said filters
  5. No unnecessary lights
  6. No glass or other unnecessarily fragile/heavy materials
I rarely can get everything on the list maxed out (like, there's always the silly LED here and there), and the choice set gets pretty narrow among the newest cases, but luckily there's still plenty older stuff around and a few "alternative designs" to cover my needs for now.
