So I'm building a motion control rig for my camera. With the end goal of doing some stop motion with it.
Its going alright so far but I've hit a major snag.  The tilt part of my pan/tilt head doesn't work. When fully loaded with camera and follow focus mechanism the motor isn't powerful enough.
The motor is 0.59Nm(84oz.in) holding torque, but it needs to be able to turn and hold about 1.5 kilos. Is there any gearbox or pulley system that might work? Or is it just time to save up and buy a bigger motor?
https://linustechtips.com/topic/907812-stepper-motor-advice/
How smooth is the mechanic stuff itself? Adding a bit of oil/grease so it can move easier might do the trick as well.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/907812-stepper-motor-advice/#findComment-11157733
Having a look at it I may need a thicker bolt on the opposite end to the motor, just to hold things straight.
https://linustechtips.com/topic/907812-stepper-motor-advice/#findComment-11157738
2 hours ago, Unimportant said:
Wondering why you're not using a servo in stead of a simple stepper. The positioning will probably drift over time. Or are you going to be adding servo feedback yourself later ?
I'm using dragonframe stop motion  software. It really only wants to work with stepper motors, plus the positioning needs to be pretty precise.
https://linustechtips.com/topic/907812-stepper-motor-advice/#findComment-11161229
