Is my power supply strong enough for a Asus Gtx1080ti?
Hielke
Dear all,
I got my eye on the Asus ROG STRIX GTX 1080 Ti O11G Gaming. My system specs are listed below. Do you guys think 650 Watt is enough for this beast of a card?
  • CPU
    Intel i5-6600K 3,50GHz
  • Motherboard
    Gigabyte B150M-D3H
  • RAM
    Crucial Ballistix 16GB DDR4-2400
  • GPU
    GTX970
  • Case
    Cooler Master CM 690 III
  • Storage
    240GB SSD Crucial BX200 + 500GB SSD 850 EVO + 1TB HHD Sata III
  • PSU
    Corsair 650 Watt
  • Display(s)
    iiyama 2560x1440p, 70Hz, 27 inch
  • Cooling
    Cooler Master Hyper 103
i5-6600K 3,50GHz | Motherboard Gigabyte B150M-D3H | RAM Crucial Ballistix 16GB DDR4-2400 | GTX970 | 500GB SSD EVO | 2560x1440p 27" | Corsair 650W
Not sure if the GPU is what you should replace now... Next gen cards from both AMD and Nvidia (Nvidia talked about it openly, AMD seems to still be preparing content) seems to support the new directX Raytracing tech much better than current cards do.  If I were you I would hold on to the GTX 970 for a while and keep track of the news.
Desktop benching:
That will take too long plus the 11 series will be unaffordable and unattainable in the first months after launch. Yes, the prices of the 10 series will probably go down by a lot but that also means I will have to wait months before I can upgrade. As you can see I have a 1440p monitor atm and therefore are in desperate need of a GPU upgrade.
Stop hoping the 10 series prices will go down. They will most likely not :P
Nothing will change (except the usual +- few % up and down) up to Q3 This year. Probably even Q4.
Nvidia said that somewhere, they believe up to Q3~ the prices will even continue to rise. Not just Mining, also Ram supply.
If new Gen launches, the will also start at these "extreme high prices" ^^
Why? Because they can. People will buy. If not, prices go down. If yes, they stay up and nvidia will only hear the sound of Cash dropping all over the place.
Just now, Darkseth said:
Stop hoping the 10 series prices will go down. They will not.
I feel the same way, so I am just going to upgrade now.
I've heard about similar stuff when Kaby Lake launches. "Intel will just copy and paste their design and call that 8th gen, so I'm gonna buy the 7700k", they said.
Go ahead if you are that in a rush.
Desktop benching:
I'm not saying that you're wrong. I'm just saying that when you look at my setup, including the monitor, the only part of my setup that is lacking at the moment is the GPU. I value 60fps gaming which might be achievable with a 1070ti, but I'm thinking: why not future proof a little?
1080 ti is actually not a bad choice for ac hieving your 70 fps lock on 1440p.
I have the same Res (but 144 Hz and G-Sync) and a GTX 1080.
I would have to turn some settings DOWN, in order to hit 60 fps in some games.
You can't have too much GPU Power. Not possible. Even if there were a GPU with double the performance of a 1080 ti, you could bring it down to it's knees.
I like this answer a lot, thanks!
9 hours ago, Hielke said:
Dear all,
  • CPU
  • Motherboard
    Gigabyte B150M-D3H
  • RAM
  • GPU
    GTX970
  • Case
  • Storage
  • PSU
    Corsair 650 Watt
  • Display(s)
  • Cooling
Yes, the power supply is sufficient.
http://www.coolermaster.com/power-supply-calculator/
Check by yourself.
Intel Core i5 4670K @ 4.4 Ghz || ASUS GRYPHON Z97 MOBO || G.Skill Sniper 16GB DDR3 (4GB x 4) @ 1600 MHz || MSI Gaming X nvidia GTX 1060 6GB DDR5 || Samsung 850 EVO 250GB SSD || Western Digital 3 TB HDD (1TB BLACK & 2TB BLUE) || Cooler Master's MasterLiquid 120 Lite || Cooler Master Slient Pro 550W (GOLD 80+) || Cooler Master's Masterbox 5 || Logitech G19 Keyboard || Dell Mouse || Creative T6160 || Dell S2240L IPS Full HD || Windows 10 Pro x64 ||
