Hello everyone, new to the site.
I just bought an Nvidia GTX 560 Ti gpu and need help picking the right power supply for it.
It says it needs 2 6pin connectors and, for my specs, a 500w PSU.
My current specs are:
Dell Precision T3400 with Windows 10 Pro X64
CPU: Intel Core 2 Duo E8500 Wolfdale 3.16ghz
Gpu: Quadro FX 570 <---Switching to a Nvidia GTX 560Ti
Psu: 100w Dell OEM
Ram: 4gb DDR2 ( Four 1gb chips )
HD: 256GB Samsung HD251HJ
CD drive: DVDR-RW
 When i look at PSU on newegg and similar sites, the connector listing are confusing. Such as 6pin+2 and 8pin and 4pin+4 etc.
Ive had great success with amazon and newegg, so i prefer to buy from them but am open to offers.
I guess im looking for as cheap as possible plug and play PSU. Hoping theres a branded one around 20-35$. Let me know guys
Thanks in advance!
https://linustechtips.com/topic/904486-need-help-finding-the-right-psu/
Can you make sure the plugs are standard ATX?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
After looking at mobo pics, this unit will do:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139201&cm_re=CX450-_-17-139-201-_-Product
(your system DOESN'T NEED 500W, even 300W will do)
Full Specs
Helios EVO (Main):
Delta - Laptop
the 650W costs about the same, getting that canny hurt encase anything else is added etc.
https://pcpartpicker.com/product/3F2rxr/corsair-cx-2017-550w-80-bronze-certified-atx-power-supply-cp-9020122-na
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
"$20 more (including rebate)"
"cost about the same"
At that rate I'd personally get the MasterWatt over it.
Full Specs
Helios EVO (Main):
Delta - Laptop
oh shit, I forgot about rebates, (we don't have them in the UK) sorry
The reason i said 500w is because i used 3 different online calculators and it says with my setup i need around 500w recommended.
1) To my LIMITED understanding, a 6+2 connector can be used for a 6pin OR an 8pin, correct?
2) So looking at PSU, i need to be interested in: wattage, 2 6+2 connects, 24pin ATX, and 12v single rail. Is this correcT?
calculators suck, they overestimate a lot.
1) Yes, when you use a 6 pin, you leave the 2 dangling off to the side, when you use 8, you plug the 6 and 2 in.
2) wattage (kinda), connects (yes), 24 pin ATX (every PSU in like the last 5-7 has one lol), 12v single rail (not at all)
You need to look at DC-DC, protections, ripple, voltage regulation, and build quality too.
Full Specs
Helios EVO (Main):
Delta - Laptop
Only a single PCIe connection, though. The 560 Ti needs two 6 pin connectors. 170W power draw.
Didn't see that :/
@DiabloFan Get the MasterWatt 550 or the CX550.
Full Specs
Helios EVO (Main):
Delta - Laptop
Than get a Bitfenix Formula 450W, thats better than getting a 650W when yo do not need it.
"Hell is full of good meanings, but Heaven is full of good works"
This seems like a good PSU for your use case:
https://www.newegg.com/Product/Product.aspx?item=N82E16817151093
Fully modular, 520 watts, $35, it comes with a 6 pin and a 6+2 pin connector as well as all the other regular connections a PSU needs, it's a SeaSonic... they're usually very reliable.
If there is an issue with this PSU someone please point this out to me because it's rare that something that seems this good actually is that good.
CPU: i7 4790k @ 4.7 GHz
GPU: XFX GTS RX580 4GB
Cooling: Corsair h100i
Mobo: Asus z97-A
RAM: 4x8 GB 1600 MHz Corsair Vengence
PSU: Corsair HX850
Case: NZXT S340 Elite Tempered glass edition
Display: LG 29UM68-P
Keyboard: Roccat Ryos MK FX RGB
Mouse: Logitech g900 Chaos Spectrum
Headphones: Sennheiser HD6XX
OS: Windows 10 Home
That's an ancient 8 year old PSU, and it's way overpriced, even at $35.
43 minutes ago, DiabloFan said:
I like the one you listed ATFink.
Any clue on rebate compensation time? Its a bit out of my budget at $50, but with the rebate i think i can make it work.
No idea about rebate.
There was I was implying it might seem too good to be true. I don't know enough about PSUs to know for sure what is or is not good to buy. @seon123's response was enlightening. If you didn't catch it, check out this thread:
Mobo: Asus z97-A
PSU: Corsair HX850
OS: Windows 10 Home
17 minutes ago, DiabloFan said:
One more question then.
I see some PSUs labeled as ATX and some as ATX12v. Will either one work? Or which one do i need?
Same
9 minutes ago, DiabloFan said:
Why not the ones listed above?
2 hours ago, JDE said:
Didn't see that :/
https://pcpartpicker.com/product/3F2rxr/corsair-cx-2017-550w-80-bronze-certified-atx-power-supply-cp-9020122-na good but non-modular
https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na good but one of the more pricey ones
https://pcpartpicker.com/product/B6XnTW/cooler-master-masterwatt-550w-80-bronze-certified-semi-modular-atx-power-supply-mpx-5501-amaab-us best fan, decent and cheaper
Full Specs
Helios EVO (Main):
Delta - Laptop
WHY do you recommend an almost 10 Year old, group regulated unit that's rather loud?!
SOrry, but that unit is shit, there are way better units out there.
Did you not read my post? Here, I'll help you out:
Quote
- snip -
-ATFink
Why would I recommend it? Because I didn't know any better. Reread the original contents of my post. I believe I explain my logic and uncertainty very clearly. I quoted myself above in case you missed the uncertainty portion. There was no need to question me in an such an accusatory manner when I specifically stated uncertainty in the model in the first place. I never claimed it was the best option. I don't know much about the M12II. I simply implied that it looked good to me but I didn't know any better and more research/consulting should be done. Thank you for further confirming the conclusion of contents already discussed in this thread...
Mobo: Asus z97-A
PSU: Corsair HX850
OS: Windows 10 Home
It's a matter of you recommending something you don't know much about.  As you can see from the next post, the OP thought it was a good suggestion based on the assumption that you know more about the subject than he does.  So I understand Stefan's frustration with you, despite your caveat.  As Twain said, "It's better to keep your mouth shut and appear stupid than open it and remove all doubt."  If you're replying to threads just for the sake of increasing your own post count, it sure as heck doesn't help the community and those who come here for educated advice.
I suppose you're correct. I thought my statement of uncertainty was enough, but considering the OP's reaction I understand it was not... And no, I'm not trying to increase my post count. I usually post <1/day.
I suppose further disclaimers are necessary especially in subjects I lack significant knowledge.
Still, the problem I see is that if everyone keeps their mouth shut nobody will learn anything. I asked for people to respond and tell me why the unit was bad if it was. People spoke up. The issue was resolved. Then people continued to question me as if I was trying to sabotage the OPs purchasing decision or something. That is why I responded negatively.
EDIT:
The current experts won't be around forever. It's best that those of us that aren't experts learn as much we can so the next wave of knowledgeable people can replace users that will eventually become inactive. How can we learn if we can't even put ourselves in positions to figure out what  questions are good to ask? I'd prefer to speak up, sound dumb, and be corrected than leave my logic flawed. That is why I believe disclaimers and statements of uncertainty are important. I will absolutely improve upon transparency in knowledge in that regard. I genuinely thank you for pointing this out.
Mobo: Asus z97-A
PSU: Corsair HX850
OS: Windows 10 Home
Believe me.  I know.  Some days, I come into these forums, read the horrors and promise myself to quit the internet for the rest of my life.
Then I'm back the next day.
