Will a AMD ryzen 5 1500x and a gtx 1060 6gb be able to run vr?
Solved by thisforumsucksassdeletemya,
Yes, the 1500x is much faster than the 4590 which is the minimum recommended for VR. And the 1060 IS the recommended so you're fine.
Featured Topics
