[Resolved] New Build Parts
2 minutes ago, herman mcpootis said:
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($259.99 @ Amazon)
CPU Cooler: Thermalright - Le Grand Macho RT 73.6 CFM CPU Cooler  ($79.99 @ Amazon)
Memory: GeIL - SUPER LUCE RGB SYNC 16GB (2 x 8GB) DDR4-3000 Memory  ($173.88 @ Newegg)
Storage: SanDisk - Ultra 3D 250GB 2.5" Solid State Drive  ($74.99 @ Best Buy)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($66.00 @ Newegg Marketplace)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($69.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($86.31 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Other: GIGABYTE GeForce GTX 1080 Ti DirectX 12 GV-N108TGAMING OC-11GD 11GB 352-Bit GDDR5X PCI Express 3.0 x16 ATX Video Card, GIGABYTE GA-AX370-Gaming 5 (rev. 1.0) AM4 AMD X370 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard ($1045.50)
Total: $1946.54
Generated by PCPartPicker 2018-03-05 10:22 EST-0500
10/10 would recommend (so often I piggyback off him lol)
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
A couple points:
-SLI is a bad idea, basically nothing supports it. Unless you know your use supports it don't bother. Just buy one fast card.
-Consider Ryzen 7, if you're going fanless Ryzen 5 (maximum).
-Consider a down draft cooler like the Scythe SCKC-210 or Noctua NH-L12 if you're planning on overclocking.
-Consider a platinum or titanium rated PSU if you are going X399/X299
-If going with AMD, make sure that the RAM is validated for the motherboard
-Consider about 650w for PSU for system with R7 and 1080Ti
-16gb of RAM of the fastest memory that's supported is recommended, but go for 32gb if your wallet allows.
-Consider airflow optimized case for TR/IEE, like Silverstone RL06
REMILIA Mk.IIIE CPU: Ryzen 9 3900X, Cooler: Arctic Freezer II 240 (Noctua NT-H2), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives 1-4 TB, PSU: Corsair RM750 MY2019, Case: Cooler Master Mastercase 5 MC500 (with add-ons, Noctua NF-A14 and Arctic P14 fans), PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), Hp Z27n (IPS, 60hz, 1440p, 8Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, ifi Zen DAC v2 + ifi Zen CAN, Littledot Mk.II (w/ Soviet Power tubes and British Mulard M8100s/Soviet Voshkod 6JP-EV/ American General Electric JAN 5654W dependent on mood), Sendy Aiva (Primary), Beyer Dynamic DT990 250ohm Black Special Edition, Audeze EL-8 Open Back, Sennheiser HD598SE (modified to be a headset, snapped headband held together with gorilla tape), Mouse: SteelSeries Rival 600, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
KOAKUMA Mk.IB (24/7 Folding Slave PC made of spare parts): CPU: Core i7 4770, Cooler: Some small antex cooler with 80mm fan, RAM: 2x 4Gb Sticks of 2400Mhz DDR3, Mobo: Asus H81i-Plus, GPU: R9 390 Nitro+ (barely fits in case), Storage: 256gb Korean no-name SATA SSD, PSU: Corsair CX550 (Gray label), Case: Antec ISK600 ITX case. [Given away to friend]
yellow nose
Total: $1946.54
Only 16GB ram? As he said he wants to edit 4k footage with premiere, 32GB is what I highly recommend
My Box of Fµn:
CPU - AMD Ryzen 5 1600
GPU - Gigabyte GeForce GTX 1080 Windforce
RAM - Corsair Vengeance LPX 16GB DDR4
MoBo - MSI B350 PC Mate
Case - Phanteks P400s Tempered Glass
PSU - BeQuiet 500W PurePower 10
Fans - BeQuiet PureWings 120mm x3; 140mm x2
Cooler - Corsair H100i v2
and THE POWER OF RGB
RAM is very easy to install either way...
Full Specs
Helios EVO (Main):
Delta - Laptop
47 minutes ago, COUPER MILLAR said:
https://pcpartpicker.com/list/ZVz4D2
If you sign up on EVGA.com you can get auto notified when the card comes into stock and get it for ~$800 us instead of the inflated price. Also the 900D is a HUGE case and with just one GPU and no custom cooling loop it would look empty. I put the Master case in as a place holder, but I would recommend going with a mid tower over a full ATX case with this parts list. I have the thermal take core x9 which is similar in volume to the 900d and it took a bit to get it looking full.
Thank you very much! This is extremely appreciated.
true
Thank you very much for the list, i really do appreciate it!
Thank you very very much, this helps a ton!
he's not the one to come up with that list.
I was getting to you, he just laid it out in a organized way, and i saw it first. thank you both for all the help today, and for that matter, thanks everyone for all the help
Thank you for putting the parts list together for me, i greatly appreciate it. i hope you have a great day! Sorry that i misunderstood some things earlier.
23 hours ago, KianFitz said:
Possibly a Ryzen 7 1800x for recording/editing? Thoughts?
I personally would still go 8700k. It beats it out in editing and in recording the 8700k has better gaming performance while an R7 has better streaming performance. But the rest of the time the 8700k wins in gaming performance.
Assuming OP can pay the $100 extra for it I really think it's worth it,
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
