980 TI Hybrid rad fan replacement question
Solved by WoodenMarker,
1 minute ago, Xalindor said:@woodenmarker i was actually just trying that. i switched all the fans to standard. GPU went from 24C to 27C then I started mining to jack up the heat and it went up to 60C with no change to fan speed.
It could be that the fan controller on your motherboard isn't fully supported by SpeedFan yet. Relying on the graphics card fan header is probably your best option.
Featured Topics
Nicolas Bossus ·
PapaAquaWet ·
Posted in Graphics Cards0 -
NASInitiate ·
Posted in Servers, NAS, and Home Lab3 -
220VoltsallCore ·
Posted in Storage Devices7 -
3
1
1
3
15
