See this:
Quote
  • Allow members to delete or lock their own posts
    If you would like something to be removed, please report it, and it will be removed by a moderator. However, a significant number of the deletion requests that we get are because the topic is solved, which is not a valid reason for deletion - by leaving the topic, it can help other people in the future.
In LTT, as in life, there are no take-backsies. No second chances. What you say and do will haunt you forever, so you better make it good enough to be proud of or bad enough that @SansVarnic wipes it out. :D
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
3 minutes ago, Psittac said:
Oh, and just saw "retired veteran".  Thank you very much for your service.
it joek
im not actually a veteran
i should probably change that
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
17 hours ago, babadoctor said:
Why can't we have the ability to delete our own posts?
For a variety of reasons we don't allow anyone to delete their own posts and this is quite common in most forums you may come across.
You do however have the ability to edit you comments utilizing the pencil icon to make changes to your comment/reply.
My hammer lies in wait ... fate calls on it from time to time. Lulz
 CHRISTIAN MEMBER
The comic sans really took away from that statement.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Many comic
Very drama
Much serious
Such sans
Wow
