What fans to use with i7-8700k?
Solved by RollinLower,
well, then you don't need very high static pressure fans, because you only need to move the air instead of push it through a radiator.
so yeah, BeQuiet Silentwings, Corsair ML120's or Arctic F12's are also very good options.
if you are looking for a cheaper but pretty sleek looking alternative Rosewill makes some of the best cheap fans in my opinion.
oelholm ·
Posted in Troubleshooting2 -
3
TheWIZARDofOZ_4 ·
Posted in Peripherals5 -
ryan1_10 ·
Posted in Graphics Cards2 -
8
weaverbeaverr ·
Posted in CPUs, Motherboards, and Memory2 -
4
Tscott ·
