Dell 27" LED QHD Gsync Monitor
Hubriz
Are you talking about the S2716DGR?
If you are I have one I’d recommend getting revision A07 as the color accuracy adjusts better from what I understand. I had to turn my brightness down and contrast a bit but for a TN panel it’s the best I’ve seen and g sync is great.
If it’s on sale for like 400 bucks grab it
It's a good inexpensive monitor.  The feature set is simple and it's built well.  Built in USB 3.0 hub and for a TN panel the colors are very good.  I'd buy it again in a heartbeat.
