11 minutes ago, Boomwebsearch said:
If 37 is 74 percent then what number is 100 percent?
9 minutes ago, Mutoh said:
50?
Correct. @Boomwebsearch you can "reverse engineer" the question if you think you have the right answer.
Take 50, multiply by 74%:
50 * 0.74 = 37
So by doing this, we have confirmed that 37 is the correct answer.
You can calculate this by doing the following:
1.
Take 74% and inverse it:
1 / 0.74 = 1.351351351351351
Most calculators have a "1/x" function to make this faster
Then you take the result, and multiply by 37:
1.351351351351351 * 37 = 50
There are often rounding errors in these calculations. Technically the above calculation yields 49.9999999 repeating, so you just round to 50.
EDIT: there may be a more accurate/easier/faster way to calculate this, but I haven't had math class in like 10 years, so, don't assume this is the method your teacher wants you to use.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11045863
50 * 0.74 = 37
1.
I thought that if 50 is 100 percent then 1 would be 2 percent. Then using that in a table you can find out if it applies to 37 is 73 percent which verifies that the answer of 50 is correct.
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11045881
73% is incorrect though.
You can test for yourself:
50 * 0.73 = 36.5
It's close, and can be rounded to 37, but 74% is the "more accurate" answer.
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11045901
50 * 0.74 = 37
1.
Brings me back to my Numerical Analysis course. Them round-off errors.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11045934
Yeah I always hated those “reverse the equation” type problems lol
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11045957
If 37 is 74% all you need to do is divide the number by the percentage.
so to get 100% you just need to do this:
37/74%
or 37/0.74
It'll give you 50 ;)
50 * 0.74 = 37
1.
Wow... so much math for such a easy question :P Let's add some quantum physics calculations in there too xD
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046003
37/74%
or 37/0.74
I quite clearly stated that it might not be the easiest or fastest method :P
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046092
Yea I know :P It's just your post kinda reminds me of something like this:
https://puzzling.stackexchange.com/questions/16799/making-24-most-complicated-way
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046117
LOl those guys make me look like amateur hour
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046122
3 minutes ago, Canada EH said:
until your out in a farmers field and your little calculator is an hour away
To be fair, my phone is literally always on me. Me being in a situation where I need to do math, and I don't have my phone, is incredibly unlikely. Especially if this was part of my job.
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046203
until your stranded....................................
oh forgetaboutit
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046206
2 minutes ago, Egg-Roll said:
That's why I always carry a pen, a pen that can write on almost anything, including steel and sandpaper (not so well).
there you go
but those two others wont be able to do squat without their calculator and cell phone.
xD
lol
The other guy is fired
and you are hired!!!!!!!!!!
You can actually think!!!!!!!!!!!!!!
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046219
oh forgetaboutit
Stranded, where? In a farmers field? If I was stranded, why would I be concerned about math (especially if the context is fixing some piece of farmers equipment)?
Plus, I always keep a 13,000 mAh battery pack in my backpack ;)
So sure, hypothetically there could be a situation in which my battery ran out, and the backup battery ran out, and I had no electricity.
But hypothetically, your pencil could break, or you could get a concussion and your internal math skills could be clouded by the injury.
I mean, if we're talking about whataboutisms after all :P
https://linustechtips.com/topic/896573-percentages-help-needed/#findComment-11046224
