I really love racing games and I want to get rivals for my PC this time instead of console. Problem is I know my current CPU and GPU config(AMD A8-5600k with radeon 7560D) Can't play the game 60 FPS steady, So I am in need for a GPU. Around $200-250 USD and that I can OC. at least 2GB of VRAM. It can be AMD or Nvidia, doesn't matter to me.
https://linustechtips.com/topic/89592-gpu-for-need-for-speed-rivals/
Apparently the game is locked to 30FPS on PC anyways. I don't know if this has been addressed yet or not.
EDIT: Good card in that range. http://pcpartpicker.com/part/asus-video-card-r9270xdc2t2gd5
System specs:  CPU: AMD Phenom II x3 705e unlocked to x4 overclocked to 2.8GHz   |   MB: ASUS M5A78L-M LX PLUS   |   Cooler: Hyper 212+   |   GPU: MSI GTX 560ti OC to 910Mhz   |   RAM: 8GB PNY DDR3 1333   |   HDDS: WD Caviar Blue 320GB, Hitachi 500GB HDD   |   PSU: Cooler Master Extreme Power Plus 500W   |   Peripherals: Microsoft wireless mouse, old mac keyboard, ASUS VS238H, Gateway FPD2275W, some speakers, Logitech Driving Force Pro
I am not sure if it has been addressed.
If you don't already have a good CPU cooler, get a Hyper 212 EVO and an R9 270. If you already have a good CPU cooler, get just a GTX 760.
I'd wait for Mantle and Kaveri.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
Unless there was a major patch release for NFS:R, it should still be locked at 30 fps.
Screw those console brown nosing devs.
Was sort of looking forward to NFS:R, but I should have known better, since its not the first time they have done this sort of thing.
There is a fix but by modders not the actual game producers.
As usual this game is locked to a crappy 30FPS even on PC just like previous BFS games, the devs say the all drive system is the reason for this.
But modders found a way to unlock it to 60FPS. Here's how:
You need to created a shortcut to the game. You have to make a shortcut to NFS14.exe. The target shortcut will look something like this:
"C:\Program Files (x86)\Need for Speed Rivals\NFS14.exe"
Now just edit this by adding -GameTime.MaxSimFps 60 -GameTime.ForceSimRate 60 to the end of it.
Now the only problem with this is maintaining 60 fps all the time. Using my GTX670 I noticed it dropping to 40-50 which made it somewhat laggy, but when it was running at 60fps it was good and smooth.
Also guys, if you have issues with fps drops, try to add these lines as well:
-MaxVariableFps 60 -MaxInactiveVariableFps 60
First thing I noticed was that it feels a bit different form the previous NFS games like The Run and Most Wanted. I wouldn't recommend buying it.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
But, when you unlock the framerate to 60FPS, the gameplay runs at 2x speed. Watch this video. http://www.youtube.com/watch?v=eDA37BmvNwM
No, that's a different fix. Which this new fix, it runs at 60 FPS at normal speed.
http://www.youtube.com/watch?v=yP74Hy0XTcY
I see.
Once you watch TotalBiscuit's review on Need For Speed Rivals, you will never want to buy it or even consider it.
Watched only 8 minutes, now I know why you said that. WTF EA? It's a good title then the fking completely ruin the game! I loved the need for speed titles, but not anymore. TotalBiscuit is 100% correct on everything he says about the game. No doubt about it.
See if you can find a cheap 7950, they are a beast
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
need for speed/cod-runs on anything..
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
