My dad and I were talking about cars and asked me if I knew if this exists: A gas/diesel powered car with a manual gearbox, but shifting is not mechanical but done by a computer of some sort (with Clutch, brake and gas pedal, no automatic)
Does this actually exist?
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/893121-electric-manual-gearbox/
I don't think gearboxes like this exist yet, going off Formula-E specs it's electrically powered but the gearbox is still a mechanical manual sequential box.
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/893121-electric-manual-gearbox/#findComment-11010091
Tesla's 1st gen roadster used a 2 speed gearbox. However, issues arose concerning the electric motor destroying the gearbox. Their later vehicles have all been one speed gearboxes since.
Though with enough voltage, and the resulting very wide torque curve, I don't imagine there being many circumstances outside racing that would require either a further gear reduction (tires spin easily enough as is), or a much taller gear (speeds on current models top at somewhere between 100-130 MPH). Also, more complex gearboxes would preclude possibility of utilizing additional motors. An AWD may have a motor on front and back, or even a motor for each wheel.
I suppose if an economy model is made with a particularly low voltage battery, then more gears may be of some benefit to reduce overall amp loads and keep wiring cool, though tight top speed restrictions will probably be necessary as well.
My eyes see the past…
My camera lens sees the present…
https://linustechtips.com/topic/893121-electric-manual-gearbox/#findComment-11010714
interesting one, but don't know why a company would do it, with all modern (hell 1990 and up) most cars have smooth gear shifts that require very little effort so to actuate them would be pointless and with Auto boxes using ether CVT, Dual clutch or other forms of wizardry to shift in 0.00x seconds doesn't seem to be much need from that side.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/893121-electric-manual-gearbox/#findComment-11010864
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/893121-electric-manual-gearbox/#findComment-11010884
1 minute ago, broron said:
just why though?
Why not? I imagine if they got the electric motor to be fairly snappy and responsive so that it doesn't act lethargic during a shift it would be fun to drive, and the trannys C7's have will take some power before they spew their guts on the ground.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/893121-electric-manual-gearbox/#findComment-11010931
the torque of eletric motors increases linearly with the rpm (higher rpm, more power), so only one gear needed to turn down the rpm for more torque
combustion engines on the other hand have a limited range
https://i.stack.imgur.com/BshX5.jpg
vs
https://www.engineeringtoolbox.com/docs/documents/1503/electric_motor_speed_vs_torque_power.png
https://linustechtips.com/topic/893121-electric-manual-gearbox/#findComment-11010957
They don't have a clutch peddle, but automated manuals were a big thing in the '00s, and the Lamborghini Aventador still uses one. They were the precursor to DSG boxes, a slower and a rougher gear change, but quite similar otherwise.
Ferrari was a huge advocate of the single clutch automated manual, first featured on the F355 and lasted until the end of the 599 GTB. It was used throughout the Fiat group, BMW used it on the E46 M3 and Aston Martin too.
I had one of these gearboxes on an Alfa Romeo 147. It was the same gearbox as the manual car and the same clutch, except the gearbox housing was a little different to accommodate the hydraulics actuators. Weirdly in operation it felt a lot like a manual, you could feel the clutch bite, even though I had no pedal, and the gear changes were crisp like a manual. It was also the most unreliable bit of the car, and being an Alfa Romeo it was up against some stiff competition for that title.
https://linustechtips.com/topic/893121-electric-manual-gearbox/#findComment-11011219
