Posted February 3, 2018 i have a 240W power supply with a gtx 1050 ti but i dont know if the 240W is good enough for an i5 3470 upgrade i5 3470=77W gtx 1050 ti=75W 4gigs ddr3 1600mhz ram Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 1 minute ago, FORTEX said: i have a 240W power supply with a gtx 1050 ti but i dont know if the 240W is good enough for an i5 3470 upgrade i5 3470=77W gtx 1050 ti=75W 4gigs ddr3 1600mhz ram HP sff? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 2 minutes ago, FORTEX said: i have a 240W power supply with a gtx 1050 ti but i dont know if the 240W is good enough for an i5 3470 upgrade i5 3470=77W gtx 1050 ti=75W 4gigs ddr3 1600mhz ram use a calculator for wattage and put in all the components you have, see if 240W Is enough Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 3 minutes ago, FORTEX said: i have a 240W power supply with a gtx 1050 ti but i dont know if the 240W is good enough for an i5 3470 upgrade i5 3470=77W gtx 1050 ti=75W 4gigs ddr3 1600mhz ram http://www.coolermaster.com/power-supply-calculator/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 Just now, CombatComedy said: use a calculator for wattage and put in all the components you have, see if 240W Is enough Do this, And then honestly, upgrade the PSU. It's likely a fire hazard or close to. Quote or tag me( @Crunchy Dragon) if you want me to see your reply If a post solved your problem/answered your question, please consider marking it as "solved" Community Standards // Join Floatplane! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 don't. please just get a new power supply, and not use OEM one that'll explode Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017) Samsung 850 EVO 240 GB 138 is a good number. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 4 minutes ago, FORTEX said: i have a 240W power supply with a gtx 1050 ti but i dont know if the 240W is good enough for an i5 3470 upgrade i5 3470=77W gtx 1050 ti=75W 4gigs ddr3 1600mhz ram I have i5 3570 1050 ti 3x4gb ram 2 hdds and an ssd 240w and it runs fine Just now, themctipers said: don't. please just get a new power supply, and not use OEM one that'll explode are you sure about that? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 2 minutes ago, Crunchy Dragon said: Do this, And then honestly, upgrade the PSU. It's likely a fire hazard or close to. lol, ive never heard of anything as small as a 240 unless its for a raspberry pi lol Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 1 minute ago, galaxyrooter said: I have i5 3570 1050 ti 3x4gb ram 2 hdds and an ssd 240w and it runs fine are you sure about that? yes Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017) Samsung 850 EVO 240 GB 138 is a good number. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 1 minute ago, galaxyrooter said: are you sure about that? It's not going to literally explode, but it's not good quality and PSUs have been known to take components with them when they die. Quote or tag me( @Crunchy Dragon) if you want me to see your reply If a post solved your problem/answered your question, please consider marking it as "solved" Community Standards // Join Floatplane! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 Just now, CombatComedy said: lol, ive never heard of anything as small as a 240 unless its for a raspberry pi lol I don't think even a Raspberry Pi draws 240W honestly. Quote or tag me( @Crunchy Dragon) if you want me to see your reply If a post solved your problem/answered your question, please consider marking it as "solved" Community Standards // Join Floatplane! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 240w is such a specific number. Most low end power supplies start off at 250 to 350w. But when then it's still a hazard. Do everyone a favor and upgrade to a power supply that doesn't scream, "I'm going to burn you and everything you love" "The only thing that matters right now is that you're here, and you're safe." Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 1 minute ago, Hiitchy said: 240w is such a specific number. Most low end power supplies start off at 250 to 350w. But when then it's still a hazard. Do everyone a favor and upgrade to a power supply that doesn't scream, "I'm going to burn you and everything you love" its like a terrorist for a psu lol Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 You cant really replace a PSU like in my case on HP 8300 elite SFF where the HP 240w is proprietary and L shaped, you could put a bigger PSU but with an Ebay adapter for similar HP Z230 workstation with the same psu and make the bigger ATX/SFX PSU external Heres a pic of my rig Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 11 minutes ago, CombatComedy said: lol, ive never heard of anything as small as a 240 unless its for a raspberry pi lol then you didn't hear a lot yet. i've had PSUs lower than that. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 23 minutes ago, CombatComedy said: use a calculator for wattage and put in all the components you have, see if 240W Is enough 23 minutes ago, CombatComedy said: http://www.coolermaster.com/power-supply-calculator/ Over calculated. To OP: just get a new PSU, it's enough but HP PSUs are all terrible. PSU Nerd | PC Parts Flipper | Cable Management Guru Helpful Links: PSU Tier List | Why not group reg? | Avoid the EVGA G3 Helios EVO (Main Desktop) Intel Core™ i9-10900KF | 32GB DDR4-3000 | GIGABYTE Z590 AORUS ELITE | GeForce RTX 3060 Ti | NZXT H510 | EVGA G5 650W Delta (Laptop) | Galaxy S21 Ultra | Pacific Spirit XT (Server) Full Specs Spoiler Helios EVO (Main): Intel Core™ i9-10900KF | 32GB G.Skill Ripjaws V / Team T-Force DDR4-3000 | GIGABYTE Z590 AORUS ELITE | MSI GAMING X GeForce RTX 3060 Ti 8GB GPU | NZXT H510 | EVGA G5 650W | MasterLiquid ML240L | 2x 2TB HDD | 256GB SX6000 Pro SSD | 3x Corsair SP120 RGB | Fractal Design Venturi HF-14 Pacific Spirit XT - Server Intel Core™ i7-8700K (Won at LTX, signed by Dennis) | GIGABYTE Z370 AORUS GAMING 5 | 16GB Team Vulcan DDR4-3000 | Intel UrfpsgonHD 630 | Define C TG | Corsair CX450M Delta - Laptop ASUS TUF Dash F15 - Intel Core™ i7-11370H | 16GB DDR4 | RTX 3060 | 500GB NVMe SSD | 200W Brick | 65W USB-PD Charger Intel is bringing DDR4 to the mainstream with the Intel® Core™ i5 6600K and i7 6700K processors. Learn more by clicking the link in the description below. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 3, 2018 26 minutes ago, themctipers said: don't. please just get a new power supply, and not use OEM one that'll explode unless it randomly happens to be a delta thats overbuild like a mofo but its not, because its a HP machine I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
