The 400C is less restrictive and better for airflow so go with that if you don't have any particular preference. The psu shroud will also be useful in hiding cable clutter especially if you don't have a modular psu.
Definitely the 400c. That C23 is HUGE. Lots of wasted space. Dont get it.
Thermaltake
As Someone with a 400C I'd much rather suggest the S340, I went from the S340 to the 400C and regretted it so much, I found for its price the 400C was not at all a fun case to build in and given the change would change back!
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
Its really that bad? These are pretty much my only 2 choices as im buying a prebuilt
In addition to this I would like to recommend going with the S340 Elite. It is about the same price as the S340 but looks much nicer. Had I known about it when I bout my S340 I would have gone with the Elite instead
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
16 minutes ago, itsaiden said:
What do you guys think? Im using 240mm water cooling and a GTX 1070 OC and wondering which one would is beter overall?
Thermaltake Versa C23 TG
Or
Corsair Carbide Series 400C Gaming Case
Just so you guys know, these are my case options. https://www.ibuypower.com/Store/Intel-Z370-i5-Launch-Special (Dont want the razer one bc of the green lights and logo)
7 minutes ago, itsaiden said:
Is that image a 400C?
No thats the C23. For comparison, here is the 400C. You can really get a good size comparison from the Reference GPU card.
Image result for corsair 400c
if its a pre-built it prob won't bother you as much, as I said I was just let down by it compared to the cheaper S340. Its still a decent case.
Redstone:
Obsidian:
