GTX 1050 problem
Sa1tama
Can't install drivers and PC can't recognize my GPU. Mobo: Asus P8H61-M LX3 R2.0
Have you tried downloading the drivers and manually pointing the windows driver installer to that driver path to try and get it installed that way?
System ProjectLuX
AMD Ryzen 5 3600
Sapphire 5700 XT Nitro+
ASUS Prime X370-Pro
G.Skill 2x16GB Trident Z Neo 3600 C16
Arctic Liquid Freezer II 280mm
Phanteks P400S Tempered Glass
Drives:
Boot Drive- Samsung 960 Evo 250GB
Games- Seagate Barracuda Compute 3TB (2016)
Audio:
DAC: Schiit Modius
Headphone Amplifier: Schiit Asgard 3
Speaker Amplifier: Yamaha AS501
Speakers: Dali Zensor 3
Subwoofer: Dali E12-F
Headphones: HifiMan Ananda & Sennheiser HD 558
IEM: Sennheiser Momentum True Wireless
Whaaaaat?
13 minutes ago, _SAITAMA_ said:
Whaaaaat?
try this
System ProjectLuX
AMD Ryzen 5 3600
ASUS Prime X370-Pro
Drives:
Audio:
DAC: Schiit Modius
6 minutes ago, NerdModeEngaged said:
try this
Can't find it:
But this happens when i try to install drivers:
Can't find it:
Download the drivers from Nvidia and right click it, go to properties then go to compatibility, after then set the compatibility mode to Windows 7 and hopefully it will install
System ProjectLuX
AMD Ryzen 5 3600
ASUS Prime X370-Pro
Drives:
Audio:
DAC: Schiit Modius
12 minutes ago, _SAITAMA_ said:
Whaaaaat?
  1. go to nvidia.com
  2. klick on DRIVERS -> GEFORCE DRIVERS
  3. select your GPU and OS from the drop-down menus, then click "start search"
  4. select the latest "game ready driver" from the results
  5. click "agree & download"
  6. open your downloads folder, look for a file named 390.65-desktop-win10-64bit-international-whql.exe or something like that
  7. double click on it to start the installation
  8. restart your PC after the installation has finished, for good measure
  9. if that does not help, report back
8 minutes ago, KenjiUmino said:
  1. go to nvidia.com
Why is my windows not compatible?
1 minute ago, John Hammersley said:
thats interesting..is it a legit version of win 10?
windows 10 LTSB - that's interesting.
have you tried compatibility mode ?
What is compatibility mode?
1 minute ago, KenjiUmino said:
look it up
and what do i do with it? Do i need to launch driver in compatibility mode? then in which windows mode?
try different settings until you find one that works
