PWM or FLX for Airflow
Solved by Jz1,
41 minutes ago, WoodenMarker said:In that case, go with the cheaper fan model and use the fan controller for them.
If you want the rear exhaust fan to react to cpu temps, you can get the pwm variant and plug that into the open pwm fan header on your motherboard.
Thats actually quite smart, I think I will go with that setup.
Featured Topics
JammJackGamer34 ·
cringowy ·
Posted in New Builds and Planning2 -
Pekokopiko ·
Posted in Graphics Cards0 -
1
deanx ·
Posted in Troubleshooting2 -
Bkstrat ·
Posted in Troubleshooting0 -
3
remo233 ·
Posted in Power Supplies6 -
2
3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
