so hi!!
I bought a my PC just 2 months and well... my graphics card gets really really hot...
Its a GTX 1080 TI aours EXTREME edition with 3 fans.
It gets very hot when i play rainbow six sidege and ghost recon wildlands for example.
It gets to more than 50C, and it's not even on  "ULTRA" settings.
Please. Help.
https://linustechtips.com/topic/876625-my-pc-is-on-fire/
Video cards are designed to handle much higher temperatures compared to regular processors.
It's perfectly normal for modern cards like your GTX 1080ti to reach temperatures up to 70-75c.
The AMD RX 570 I just bought is designed on purpose to adjust its fan rpm to only work harder at cooling the card once the temperature reaches 72 degrees Celsius.
It constantly spins the fan up or down to keep the temperature there and if the temperature goes below around 60 degrees Celsius it just stops the fan to make the card more silent.
https://linustechtips.com/topic/876625-my-pc-is-on-fire/#findComment-10852491
50C is nowhere near really really hot. I have an EVGA 1070 SC and it's usually around 60-65C. If you really want to drop your temps even more try adjusting the fan curve, make sure your case has good airflow and enough fans to push enough air.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/876625-my-pc-is-on-fire/#findComment-10852493
50Cº is not considered hot, above 80Cº is.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/876625-my-pc-is-on-fire/#findComment-10852497
50C isn't even close to the max temp that the 1080 Ti will begin to throttle. I believe that Nvidia has placed a 90C max temp for Pascal.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/876625-my-pc-is-on-fire/#findComment-10852505
In a way it starts throttling at 53Cº already if you count GPU Boost 3.0 mechanics... obviously not what OP has in mind though which is the limit safe temp, Pascal cards on their BIOS lists 94Cº and only severely throttles or shuts down past it.
Personal Desktop":
https://linustechtips.com/topic/876625-my-pc-is-on-fire/#findComment-10852557
