1920x1080 for a large monitor?
SwiftXShadow
I have the specs to use 2k or 4k  but since i still find games that can drop my fps below 60 with 1920x1080 (witcher 3 rarely, fallout 4) then i dont really want to go to 2k or 4k till technology advances a bit more so anything can be run on a stable 60.
So i am thinking of getting a 32 or 28 inch monitor, but i was thinking since the amount of pixels i will have will stay the same 1920x1080 will the quality drop be noticeable form like a 24inch monitor, in gaming?
kinda yeah depending on how much you care about it and how close you are to your screen. I personally don't think a 32" looks good at a monitor viewing distance
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
I would stick between 24 & 27" for a 1080p monitor, since most of those have the best of other features as well such as. 5MS or less refresh rate, IPS panel, good viewing angles, good color accuracy. I've been told that going over 27" will produce visible pixels even if you're not sitting too close. Truthfully though you'll only know by testing one in (I hate to say this) Best Buy. Even if their colors, viewing angles & build quality really sucks. Just to get an idea of how close you can sit to a given size until you notice the pixels.
Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3
i have a gtx 1080 so i guess 2k could be an option but like i said even on 1080 i find games that drop below 60 fps.
What would be the highest sizes to go with on 2k
I'm sorry I don't know, I've actually made a promise to myself that I won't ever go over 1080p until mid end hardware can always push 60FPS at it. If I could upgrade from my 900p very basic Acer TN panel it'd be to what I previously describe to ya.
even high end ones cant lol, like i said with the gtx 1080 i have had witcher drop to like 40 a few times and fallout 4 is a constant low fps in citys lol
U'll need like 1080ti. although it depends on the game, On heavy AAA title 60fps average at max settings is a bit hard to achieve with 1080
To answer your question there is something called Ppi or pixel per inch(pixel pitch) its what it is the amount of pixel per inch.
So to compensate for a large sized monitor they will use a wide pixel pitch resulting in a blurred looking less crisp images if u sit close from it.
Meaning u'll be able to notice a gaps between pixels.
I'd say 30inch is way too big for 1080p monitor even for 2k its stll too big imo.
The proper size for full hd it should be around 19-24inch for Qhd u could do from 20-27inch or 30 if u dont mind the wde ppi or you are sitting far away from your monitor like 2-3meters.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
I game on a 4k screen with my 1080 and it's fine. Remember that you don't have to turn on AA anymore and can probably also lower some other settings without noticeable difference in image quality.
1080p for 32" is ridiculous, QHD minimum!
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
so u never had ganes drop below 60fps? on ultra with out AA?
Well yes I did obviously. But depending on the game, I'm still fine with 45fps and up.
Ofc in fast shooters 45 sucks, but for example Witcher won't be much of a problem. For me at least.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
For 1080p, 24" to 27" is ok. (Ultrawide 34").
32" is better go for 1440p.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
