New monitor text is pixelated and color fringed
I just bought a 24 inch BenQ Zowie 144hz monitor and have it as a dual display with my old 75hz 21 inch AOC monitor. The old monitor looks fine, but the Zowie is pixelated and the letters have small red and green shifts around the edges. I made sure it was 1080p when I was changing the refresh rate, so that's not the problem. Any solutions?
Model: BenQ Zowie XL2411
Tried switching cables, etc?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I only have the one DVI cable that came with it. Should I try HDMI?
Make sure the monitor and the video card are both configured on Full RGB or Full YCbCr  - if one outputs Limited and the other is configured for Full or the other way around, the colors won't look right.
Ugly reds are often a result of your video card outputting YCbCr 4:2:0 instead or YCbCr 4:4:4 ( Full YCbCr) or Full RGB.
Make sure you don't have Overscan or Underscan enabled in the driver settings.
How would I go about checking that?
