Monitor for Christmas
EJOE
Hello, I'm looking for a monitor that's 1080p (my 1060 can't handle 4k) wide, and possibly curved if I can fit all this in the budget of 500-700 US$. I will also be playing Xbox on this WhIch uses HDMI. I use HDMI for my PC too. So an HDMI port would be great
I'm currently eyeing this ome
Acer XZ350CU Black 35" 21:9 Ultra-wide Curved Monitor, FreeSync 144 Hz 4ms 2560 x 1080 Gaming Monitor 300 cd/m2 100,000,000:1 HDMI Display Port w/ Built-in Speakers http://www.newegg.com/Product/Product.aspx?Item=24-009-847
Greatly appreciated
EJOE
Greatly appreciated
EJOE
You could always go with something like this, run games at lower quality for now, and upgrade your GPU later too. https://www.newegg.com/Product/Product.aspx?Item=9SIAB715ZF6207&cm_re=3440x1440-_-9SIAB715ZF6207-_-Product
14 minutes ago, Crunchy Dragon said:
That looks pretty good, LG has some 1080p ultrawides, although those weren't above 100Hz
Yes they do. This one is 144hz for $450
https://www.amazon.com/LG-34UC79G-B-34-Inch-21-UltraWide/dp/B01LW5CGIS/ref=sr_1_1?ie=UTF8&qid=1511840986&sr=8-1&keywords=144hz+ultrawide+monitor
2 minutes ago, EJOE said:
I'm not sure I'm going to run my games at a lower setting (how low?)
I'd go with the LG. They are known as being the gold standard on Ultrawides. Plus that Acer looks super thick and heavy for no reason.
7 minutes ago, EJOE said:
So the Acer or this one?
Oh BTW they also have that same LG monitor with G-Sync for $650 since it still fits in your budget.
G sync?
Oh sweet I'll keep that in mind
Just now, EJOE said:
G sync?
Adaptive refresh rate, it syncs your FPS to your refresh rate so there is no screen tearing. G-Sync is Nvidia's version, Freesync is AMD's version.
