I NEED HELP! With 1070
Murfe
Hi I have a psu with 2x 6pin connectors for the gpu but the gpu has 1x 8pin slot what do I do? can i just plug one for the 6pin connectors into the gpu and will it still work>?
This is the GPU Asus GTX 1070 Dual OC 8GB Graphics Card
Use a two 6pin to one 8pin adapter instead. Make sure it's well built though. 1070 wont work with only a 6pin.
Desktop benching:
Probably a pretty old PSU if it doesn't have the 6+2 pin breakout type cables. Which one is it? (make and model, not just wattage)
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
i dont know what is it, here is a pic
