portable monitor (tablet)
Filips
Hi, guys!
I am on a very tight budget but need a second monitor -  mostly for word and 3d modelling, sometimes for programming, so things like refresh rate, resolution and brightness aren't too important as long as text is readable. I am usually on the go, so big monitor is not an option. I am wondering, has anybody tried to use a cheap chinese tablet as a second screen? is it useable?
tablets usually only have output ports and no video inputs, you will need to search for a while to find one that has an actual input.
There is software that allows you to extend your desktop to a tablet Android/iOS.
But this comes at the cost of latency.
You'd also need WiFi, the crappier the WiFi the crappier it is going to be to use it.
When the PC is acting up haunted,
who ya gonna call?
"Monotone voice" : A local computer store.
*Terrible joke I know*
a kindle fire? then use somehting like team viewer
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
yup. thats what I was thinking about. wifi should not be a problem, just thinking how big is the latency, like is it possible to watch vids or do something else than reading, asuming that wifi is reasonably fast. image.png.d978a58a7577be733e9bd089853fedbf.png
