I need help with my monitor
MxKeks
Well i realized a weird and pretty annoying problem with my monitor. I have a multi monitor Setup and on my main screen (Asus ROG PG278QR) some images look really bad in quality compared to my second screen (some cheap lg 100-150€) one.
To show you i made some pictures with my phone, see for your self. The Problem is this pixly look on black/grey areas
The main monitor (Asus)
and down below my secondary monitor (LG)
If you know what to do please tell me, because, i am out of idears
I looked a little deeper into it
and i created this Test PictureTestpic.thumb.png.fe029eb925cdd706bd221a43f1d9221f.png
The Image looks like that on my Main Screen, 59fe3055658a3_AsusTestpig.thumb.jpg.469fc0121cc1e63475745e93923d6a01.jpg
and both sides the same on the second monitor
looks like clouds from the backlight also you should check the connections just to make sure.
Well, I already tried to connect the Monitor with the HDMI from the second monitor but, that didnt halp the issue. Clouds from the backlight ? What could i try do to fix that ?
Hmm looks like i fixed it by lowering the gamma. Thanks for your help :D
