Does Xbox One S Controller Works Wired Without The Battery ?
Solved by unknownmiscreant,
I have an Xbox one s controller. It works with or without batteries in wired mode and any bluetooth adapter can be used. I have used internal ones in laptops, USB ones, and ones on PCIe add-in cards with 0 issues.
Other than the stock one that came with my laptop which is very weak. Everything had issues with it, mice, keyboards, phones.
Definitely get some rechargeable batteries though. I worked out once that they pay for themselves after 4 charges. Assuming you already have a charger. Make sure to get a decent one, as it will increase the lifespan of your batteries. I can explain why if you are interested.
