Just now, RKRiley said:
Because the signals can travel down the wire much faster than they can through air.
Not really it more so has to due with compensation for lost data during transmission, both travel at light speed
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
2 minutes ago, RKRiley said:
Because the signals can travel down the wire much faster(well not much, but fast enough to make difference) than they can through air.
True, but there is another layer. Its the signal integrity. Wireless is fundamentally slower, as there is much more interference with a wireless connection, so more data has to be transmitted to ensure accurate tracking information is being sent.
With wireless, sometimes the information has to be resent multiple times.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
In older days, it was because there was processing needed to transmit and receive. But I'm pretty sure processing that is much faster today to the point where it's imperceptible.
Signals travel through copper at about 2/3 the speed of light. Radio waves in air are basically at the speed of light in a vacuum.
I think the gauge of the wire comes into play but I know for a fact that electricity on the grid for instance is similar to light speed (approx 285,102,627 m/s on 12 gauge wire) so a little less but not much off.
1 minute ago, Kingjames0202 said:
well than everyone just needs to make the signals stronger similer to the logitech g602
It's not only strength but p e n e t r a t i o n power and other factors. Also depends how far the receiver is.
If that mouse is new return it and exchange it, Razer stuff tends to be low quality and break.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Normally, if your mouse has very good wireless system, the input lag would be minimal, and impossible to detect, especially if the sensor is close by. But technically, yes.
However, to answer your question:
  • On Wireless, the mouse needs to conserve power. So depending on the mouse, different things can happen. The sensor polls less, the mouse goes quickly to sleep the moment it stops moving, sends packets the receiver less often when the mouse is not moving, and 'causes a delay when the mouse moves and the packet are sent faster due to the detection of movement algorithm overhead (and processor), etc.
  • Overhead by passing though additional chips needed to send the signal wireless and conversion from wired to wireless and wireless back to wired.
  • Loss of packets due to normal air travel and interference.
  • Signal degradation due to distance (links to above point)
Why do people keep saying this... Another version I've heard is "wireless can go in a straight line and not have to follow the cable so it's a shorter path".  Both are completely ridiculous.  Any impact that either of those things have will be on the order of nanoseconds, ie, about 1 million times less than the scale input lag can be noticed on.
Stop saying light speed. It doesn't go light speed. Fiber optic doesn't even go light speed, even if you make one in 100% glass and in a straight line. Light only goes to light speed, in a 100% theoretical vacuum.
I think the gauge of the wire comes into play bu I know for a fact that electricity on the grid is similar to light speed (approx 285,102,627 m/s)
Considering that electricity is a transferring of electrons, which have mass, it's slower than that.
It isn't transferring its oscillation, ie it's an em wave in essence
Even that doesn't go at the speed of light  in a vacuum in a conductive medium: https://en.wikipedia.org/wiki/Velocity_factor
I said similar to light speed, not equal, stated 12 gauge wire plus gave a value, and even mentioned gauge would likely play a role.
Any way we're off topic at this point, @GoodBytes gave a great answer, so
@Kingjames0202 theres your answer.
