Need help picking a graphics
Alright, here we go.
Computer: HP Z220 CMT Workstation
OP: Windows 7 Pro
Speccy: http://speccy.piriform.com/results/5jZnwWzO2vcYNcKkoHoGawl
Budget: 500 USD (EDIT: $470)
Needs: Run most AAA games at 60 fps, 1080, 60 hertz. Potentially higher quality via super sampling. I plan to use it for gaming and perhaps some light 3d /Movie work. Mainly want to play indie games and the occasional AAA game. Want to play at max settings, unless the game is insane a la The Witcher 3. I asked Reddit and was recommended a GTX 1060, but I am wondering if perhaps I should go with a factory overclock??? I don't really mind a mild overclock if I really need it, but would really like to not have to do that. Not to mention if my motherboard can voltage overclock graphics cards.
Side note: as you can see I have 2 graphics cards as of now without SLI, each connected to a separate monitor. Are they each powering their own monitor? Also I just switched out a graphics card for these two, installed drivers using Geforce experience, is all good? I heard tell that you need to manually uninstall the old drivers.
Edited by karnathe
Incorrect Budget.
11 minutes ago, Max_Settings said:
Your budget is $500 for a GPU? Then get a 1080
+1
AMD basically isn't an option at this point, and NVidia only has one card at this price range, so you only have one choice.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
Only because there are no cards at MSRP because those damn miners.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
Even if the 64 were at MSRP a 1080 is still a better card.
I don't agree with this statement.
Unless you are doing compute, the 1080 and 64 just go back and forth on who is faster, and the 64 has much higher power draw.
I would rather spend less if i can still get what i want. a 1080 is overkill I think. Also, MY fault completely, i do not have a budget of $500, I have budget of $470, i remembered incorrectly. a 1080 would work and it would be seriously future proofed, but from what i know of graphics cards (which isn't much) It seems overkill.
not to mention i am unsure if my case can fit a 1080, or if my core i7 will be the bottleneck.
