Posted September 25, 2017 Of every forum and guide I've searched, everything says my hardware is compatible and that my setting are correct yet the VMs that I create regardless of how many Virtual CPUs I assign report 2. One per physical processor. I learned this was due to a number of features that the hardware must support and settings that need to be enabled in the BIOS including VT-x, VT-d & feature support for Unrestricted Guest (UG) and EPT. I have checked and verified that all of these things are enabled and I don't see any of the hardware being incompatible yet despite this the virtual machines continue to display 1 core per CPU so I'm at a loss. Hardware: CPU: 2x Intel E5 2670 Motherboard: ASRock EP2C602-4L/D16 RAM: Kingston 128GB 1600MHz ECC Unbuffered Software: FreeNAS-11.0-U3 (c5dcf4416) VM software is pre-included and is refereed to as "bhyve" or BeeHive. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/838902-freenas-110-vm-virtual-cpu-assignment-issue/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 25, 2017 I mean is much better posting this on FreeNAS forums. It also could be a bug, i mean VM feature is still alphaish. I have seen people with supported build with alot of problems while others with unsupported seem to be working more successfully than them. Magical Pineapples
