you have power and your pc is running. congratulations!
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/834136-help/#findComment-10425829
It's the 'hey, I'm turned on!'-light. The light that is off is the hard drive activity LED.
https://linustechtips.com/topic/834136-help/#findComment-10425844
16 minutes ago, Tazo Davitadze said:
its first time i saw this blue lighting
case : Deepcool tesseract
what is meaning of this blue light?? HELP
The lightning bolt is actually a scar and clearly indicates your computer survived the killing curse.  Unfortunately, it's now a horcrux and needs to be stabbed with a basilisk fang.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/834136-help/#findComment-10425959
Tape it with black isolating tape so it doesn't blind in the dark and you can sleep.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/834136-help/#findComment-10425992
OP it is your Power Indicator Light.
As @Princess Cadence suggested, tape it over with black tape and call it a night. ;)
 CHRISTIAN MEMBER
https://linustechtips.com/topic/834136-help/#findComment-10426022
