R9 290 custom air cooling?
Go to solution Solved by WoodenMarker,
You can get the NZXT G10 and a compatible liquid cooler for it.
Basically the Kraken x40 because there's like no point getting the x60 for a gpu.
https://linustechtips.com/topic/83407-r9-290-custom-air-cooling/#findComment-1136480
The Prolimatech MK26 is said compatible, as is the Arctic Cooling Accelero Xtreme 3 (you just have to add little heatsinks). There's also a Gelid one that is compatible afaik.
Desktop : i5 3570K@4.3GHz, ASRock Z77 Extreme 4, Sapphire R9 290, 2*4Gb DDR3 1866mhz, Intel 335 180gb, 2*1tb, all wrapped up in a Corsair Air 540 and fed by a Seasonic Platinum P760,  Windows 8.1 Pro
Laptop : i7 4700MQ, 2*4gb DDR3 Sodimm 1600mhz, Nvidia GTX780m, 70% Gamut Full HD Matte Display, 2*128gb Sandisk Ultra Plus, 1*256gb mSATA Crucial M500, Fedora 20 & Windows 8.1 Pro
https://linustechtips.com/topic/83407-r9-290-custom-air-cooling/#findComment-1136617
I use the MK26 myself, +1 to this post.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/83407-r9-290-custom-air-cooling/#findComment-1152040
