Hello everyone i was just wondering about Linus's rgb pc build and it looks amazing but i want to change some of the parts like the motherboard for ix formula because it has more features and the battery to a 750 instead of 650, will i still be able to do the build and would it be worth it? will i be able to run high end demanding games with it today?
https://linustechtips.com/topic/833835-linuss-rgb-build/
The parts list he used for it is pretty crap. I would suggest you go for an i7 instead (or if you're willing to wait coffee lake is coming in less than a month which will bring 6 cores to the mainstream Intel lineup). Also what do you mean by battery? Do you mean PSU?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422256
1 minute ago, Ehsan said:
by battery i meant power supply i got a brain fart for a second
750w isn't really necessary :)
If you want an awesome RGB PC I suggest you not follow by that build since there are the above mentioned bad choices as well as some other stuff (spending $100 on cpu cooler instead of getting a gtx 1080 instead, the case has literally GARBAGE airflow).
You could build a 7700k/8700k+1080 ti system that still has a lot of RGB for a similar price. LTT really didn't do a good job of making the parts list. If you want, I could create a $2000 parts list as an example of what you could do with the budget.
Also side note, plz quote me in the future or I might not see you replied! :)
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422278
4 minutes ago, Ehsan said:
@DocSwag Thank you heaps and my budget is around $4k i just need a really good pc build that will last me years and of course one that has alot of rgb xD
Ok, here's a killer pc that will absolutely stand the test of time.  Add the cost of the rgb case and fans and you are god to go!
PCPartPicker part list: https://pcpartpicker.com/list/Ypyyhq
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor  ($429.99 @ Amazon)
Motherboard: Asus - CROSSHAIR VI HERO (WI-FI AC) ATX AM4 Motherboard  ($269.99 @ B&H)
Memory: G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Memory  ($409.98 @ Newegg)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card  ($794.99 @ SuperBiiz)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.89 @ Amazon)
Total: $2024.84
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422570
Hey guys i was wondering if it is worth it building the rgb pc Linus created i was thinking about changing some of the parts though like the mother board for a ix formula instead of the ix hero and the psu for a 750w and probably the i5 7600k for the new upcoming cpu from intel. i am going to build this at australia so the cost is gonna be like doubled cause of currency. will it be able to run everything with ease? like run high end demanding games with above 60 fps easily? will i be able to stream with no fps drop or stuttering?
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422828
Most of the parts would be fine however i'd change some of the main components.
First go for coffee lake, ryzen, or an i7
Use a single gpu unless you're going 4k and money isn't an issue
8 or 16gb of ram (16 preferably)
And this is only preference but the block on the kraken x62 line is the coolest looking aio block so i'd swap that for the corsair aio
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422854
No no no no no
none of this
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422862
nah money isnt that big of an issue for me
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422867
what then? xD
Something that isn't 7600K
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10422879
Include monitor and peripherals or no?
If you want to stream with NO FPS drop at all you're gonna need a second system for capturing and streaming and whatnot. I don't know of any system outside of a dual system that can stream without any fps being sacrificed.
With a $4000 budget though there's no doubt you'll probably be able to crush 4k 60 fps at high or ultra.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/833835-linuss-rgb-build/#findComment-10423659
