Gpu or monitor problem?
Ezsno
My friend's gpu is a gtx 950 and when i change the resolution to it's native resolution the screen goes black.
What type of cable are you using to connect it?
He's using a vga with a dvi adapter
Is this the desktop resolution you are changing or in game resolution? Are the drivers up-to-date?
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
Desktop resolution. I don't know about the drivers yet.
Start with updating those.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
Okay i'll tell my friend
What is the monitor resolution?
But if that doesn't work is there another way?
1920 x 1080 - goes black screen
1600 x 900 - works fine
That's weird. Both DVI and VGA are rated for 1080p. The only thing I could see being the issue is maybe it doesn't like the adapter.
Probably
Probably
Do you have any spare cords that you could try connecting the monitor with instead?
he tried using another vga but it's still the same
No HDMI or anything like that to test?
He only has vga sadly
You don't have any HDMI cables laying around anywhere? Not even connected to a tv that you could unplug to test for a second? Damn that is a shame. I have a strange suspicion it maybe related to using VGA.
It's not my gpu/monitor btw, also we live like 40 km apart (so i can't lend him my cables)  Im only posting it here because he's lazy.
also i don't know why he doesn't have any connector other than a vga.
Well then that sucks. I mean he could try buying a different cable and see if it fixes the issue but it may or may not work. I guess maybe they could return the HDMI cable if it doesn't.
I'll try asking him that (I'll probably just go to his place and bring him the hdmi)
Yeah it is definitely worth the try because I can not think if a reason why it would be a gpu issue or a monitor issue unless the monitor isn't 1080p.
Yeah i'll try it tomorrow. it's like 2 am right now thanks anyway :D
Oh dang thats late. Well good luck.
